Enable Router Discovery globally so that the device supports Router Discovery. Use ICMP Router Discovery to enable hosts attached to the broadcast network to discover the IP addresses of their neighboring routers.
If you enable ICMP Router Discovery globally, you automatically enable it for all VLANs. If you do not require ICMP Router Discovery on a specific VLAN, you must manually disable the feature.
Enable ICMP router discovery on the device and confirm that router discovery is enabled.
Switch:1>enable
Switch:1#configure terminal
Switch:1(config)#ip irdp
Switch:1(config)#show ip irdp
        VRF "GlobalRouter" (Global Routing Table) : Router Discovery Enabled
Use the data in the following table to show ip irdp command.
| Variable | Value |
| interface | Displays route discovery interface information. |
| vrf WORD<1–16> | Displays route discovery for particular VRF. |
| vrfids WORD<0–512> | Displays route discovery for particular VRF IDs. |
